Still working this engine over. I pulled he lower unit and replaced the water pump. When I tried to stab it back, the splines would not line up, even though I had not moved anything. I turned the shaft to the crankshaft and the splines lined up, but, the splines to the shift linkage did not line up. I had my brother move the shift lever slowly back to neutral, until they lined up and it went together. Problem is, it is in forward all the time. Do I just pull the lower unit with the shift lever in neutral position, as it was went it went together, then once split, move the shift lever to forward, and try to go back with it?
Thanks!
Thanks!
