"I have had this boat since br
"I have had this boat since brand new. I put a four barrel intake and carb on it shortly after purchase. The first motor I burnt a hole through a couple pistons. Put heavier pistons in and ended up burning the top of the block out of the cylinders. Put a different engine in and melted the center out of the plug and sucked a valve into the head. I have a low to midrange performance camshaft and an automotive intake. I know that I need the marine intake, but will that solve the problem. When it starts to go bad, it will backfire into the carburetor. The plugs start out black and then burn out the centers. This happens mainly on the center four cylinders. Anyone with suggestions?"
