Ok, Will replace the bendix, see how it goes. I bought the motor and was told it was blown. The person I bought it off said one day it worked and the next it didn't. He said it just would not turn over. Turns out from what I have seen so far, is the bendix wasnt spinning the flywheel. He had the baffle plate off and told me he had a bad piston. I have a bore scope, checked the piston with it quickly. I was able to move the flywheel by hand and slowly turned it. It turns very smooth and I slowly checked the pistons over. They seem ok. I put a washer to prevent the bendix ( for now, new one ordered) from going up and spinning the motor. I put the Baffle plate on ( still waiting on new gasket) just to do a quick compression check. I will do it properly if the motor is ok. All 3 pistons have equal 120 psi. I did not put fuel to it I just spun the motor to get a compression check. So I have invested in gaskets and a bendix. I hope it turns out of. What else should I be checking on this motor. I'm crossing my fingers that this is is.
