thanks for the imformation, if I understand you right it will not hurt to run this engine with tube where it is,it just looks a little out of place.
QUOTE=hotrod53;348665]a picture would help, but if you mean a small hose that comes up in front of the shift shaft on the leading edge of the lower unit, that is a speedometer tube. Maybe your motor doesn't use it. There should also be a very small hole in the lower unit on the leading edge where water will enter and go up in that tube. If you don't use it, remove the tube and fill the hole in the front of the lower unit with JB weld. I had the same situation when I replaced my L/U.[/QUOTE]
