Osanxhjaku
Hello all. I recently purchased a 1988 searay with a 3.0 mercruiser it cranks but I can’t get it to start. I’ve changed plugs and wires, distributor cap, ignition coil, rotor, starter solenoid. Can’t get it to start or get spark. It has a pertronix electronic ignition ignitor on it so points and condenser isn’t an issue. Checked and there is 12v at the coil. Not sure what else what else to look for. The kill switch at the throttle handle is wired with one wire to another from the harness and they are blue and purple stripe. Not sure it’s wired correctly any advice would be greatly appreciated. Thank you in advance!
