1988 Johnson VRO 70 Horse
rthomas568
"Hello, I just purchased a ver
"Hello, I just purchased a very strong running VRO. I'm curious if I should disable the Oil Injection Pump or leave it alone. Engine has little hours on it and runs very quietly. I noticed a few minor oil drips after we use it from the Carb. I'm thinking to much oil from the pump?"
"u need to install/upgrade you
"u need to install/upgrade your pump(if it has not been done-or,unknown)...or disable the oil side..do a search on here..joe reeves has a good write-up on disabling it."
"Any drips from the carburetor
"Any drips from the carburetors should be the fuel mixture, not pure oil. I suspect this is what you meant. If the drip is with the engine tilted, I'd assume that the front plate gasets require replacing. If a drip when the engine is in the normal running position, then I'd suspect that that carburetors are due for a cleaning and reworking.
The VRO question? Read on......
(Warning Horn Wire Routing)
(J. Reeves)
The three wire plastic warning horn that came into existence with the VRO era must have the wires connected in one manner only. To have them reversed results in having the horn omit erratic false warnings. Notice that the horn has two plug on type terminals and one black wire that is incorporated within the horn. The "TAN" (sensor) wire must be connected to the terminal closest to that black wire..... with the "PURPLE" (12v) wire connected to the terminal fartherest away from that black wire.
(Testing Warning Horn)
(J. Reeves)
On VRO equipped engines where the VRO automatic fuel/oil setup is still being used, make sure that all components are connected as required. This would include the VRO pump wiring harness itself, the oil tank wiring, the overheat sensor(s), and if so equipped.... the vacuum switch that is standard to many V6 & V8 engines.
If the VRO automatic setup has been eliminated and has been disconnected properly, and the fuel and oil is being premixed, make sure that the overheat sensors are still connected, and the vacuum switch if the engine is so equipped.
Turn the key to the ON position (Engine Not Running). Find the TAN wire at the cylinder head(s), then ground out the portion of that wire that is part of the engine wiring harness. If that Tan wire connector has the knife type connector where as it is exposed simply by sliding the rubber insulator back, it does not need to be disconnected.
Grounding that TAN wire should cause the horn to sound. If it does not, find out why as that's the only warning you'll receive should the engine overheat or have some portion of the VRO system fail, or have the engine encounter a fuel retsriction if it is equipped with a vacuum switch.
(Priming The VRO Pump)
(J. Reeves)
When hooking up or installing a VRO whether it is a new or original VRO pump, it must be primed in order to dispel any air that might be in the oil line.
Have the Oil line attached to the engine fitting BUT detached from the VRO. Add a piece of fuel hose if necessary to the oil line so that it can be aimed into some sort of container.
Pump the oil primer bulb, catching the oil flowing out of the line into the container until you are absolutely sure that you have rid the oil line of every bit of air that might have been trapped there.
Now, connect the oil line to the VRO and secure it. When the oil line is secured, apply pressure to the oil primer bulb ONE TIME only. That's it.
(VRO Changeover Judgement Call)
(J. Reeves)
The VROs first came out in 1984 and have been upgraded quite a few times. In my opinion, back around 1988, they had perfected them but I think that they were upgraded even more since then. As long as the warning system is operating as it should, I feel quite at ease with them.
Some boaters have voiced their thoughts such as "What if that overpriced plastic horn should fail while I'm under way for some reason, and the VRO decides to fail five minutes later?" Obviously that would result in a big problem which really brings their fears into view.
The word "ease" is the key word though. If one has the slightest feeling of being ill at ease with that setup, then they should take the route they feel more at ease with. A judgement call each individual would need to make on their own.
(VRO Pump Conversion To Straight Fuel Pump)
(J. Reeves)
You can convert the VRO pump into a straight fuel pump, eliminating the oil tank and VRO pump warning system, but retain the overheat warning setup by doing the following:
1 - Cut and plug the oil line at the engine so that the oil side of the VRO pump will not draw air into its system. Trace the wires from the back of the VRO to its rubber plug (electrical plug) and disconnect it.
2 - Trace the two wires from the oil tank to the engine, disconnect those two wires, then remove them and the oil tank.
3 - Mix the 50/1 oil in the proper amount with whatever quantity fuel you have. Disconnect the fuel line at the engine. Pump the fuel primer bulb until fuel exits that hose with the tint of whatever oil you used. Reconnect the fuel hose.
That's it. If you want to test the heat warning system to ease your mind, have the key in the on position, then ground out the tan heat sensor wire that you'll find protruding from the cylinder head. The warning horn should sound off.
"Thanks Joe! [img][/img] &amp
"Thanks Joe!
& JW"
