I’m looking for some guidance on what to do with the engine listed in the title. It is a 48hp with two cylinders.
So I finally got the motor running smooth after dual carb rebuilds and a new battery. Took it out on the lake and it was running great for about 5 minutes.
Then the buzzer warning started going off from the shifter box. There are no indicators to clarify what this noise means but in the manual it says it’s an Overheat alarm. It was constant not intermittent.
Well...about 10 seconds later I heard a gear grinding noise and lost drive to the prop. Yes, I turned it off then.
Out of curiosity, about 10 minutes later I turned the engine on and the alarm was gone and the prop would engage slightly. I didn’t go full throttle but it was definitely turning but still with a grinding noise. Turned it off very quickly.
Does anyone know if these are separate issues or not?
Any guidance would be appreciated. I’m trying to fix this thing up for an older friend that just wants to go out on the lake a few more times before he is fishing from the clouds.
Thanks.
Thanks.
