Trying to isolate fuel issues with this motor that came with an old Mako I purchased. Problem is engine is stalling out when trying to get up on plane but works fine when pumping the bulb constantly. Bought a new fuel line/pump combo line and a new see-through in-line filter. Ran motor from an auxiliary tank with a clean mix of fuel to rule out old boat tank issues. When idling, the fuel is not much more than a drip coming out of the fuel line from the tank and being pulled through the bottom of the filter to the motor. If I pump the bulb the filter fills up a little over half way but after about 15 seconds is goes back to basically being empty. Shouldn't that filter be at least half full at idle? I have a feeling if I took it for a ride I'd see that filter completely emptying out when trying to get up on plane. For reference this motor had the VRO pulled at some point and replaced with an EMP brand pump that appears to be fuel only. The pump works off of the engine pulse and is not electric. I've taken the pump apart and inspected all ports, diaphragms and gaskets and they appear to be fine. What could be causing this very weak pull of fuel? Engine not pulsing properly? Bad pulse limiter? Vacuum issue somewhere on this motor I haven't considered?
