1988 Johnson 90 hp
ned_dixon
"I've got fire on 3 cyls.
"I've got fire on 3 cyls. No fire on #1. I swapped coil between # 1 and # 3, still no fire on number one. (So not the coil.) Could it be the power pack? Other ideas? Please!"
"Thanks! Just wanted to confir
"Thanks! Just wanted to confirm with a board expert. Would you rather have a beer or a snow cone? (I have beer, I'd have to get the snow cone.)"
BTW - could some other underly
BTW - could some other underlying problem have caused the power pack to go out... or probably just old age?
"keep in mind,the entire ign s
"keep in mind,the entire ign system,should be checked,before repl parts...at the least a visual,of the components.......if components look ok,..no melting of stator,raw wires,...cracked coils etc...............i'd stick a pack on it!"
"In agreement with JWB. Unfort
"In agreement with JWB. Unfortunately I quit drinking many years ago. Doc says it would kill me, wife said she'll leave me.... didn't want to die lonely (grin). Give my share to JWB."
"I have a wiring problem. I c
"I have a wiring problem. I can start the motor with the switch but I can't shut it off. I tried a different switch, but got the same results. Must have some wire crossed. Any idea where to start looking?
(Still running on 3 cyl. Can't find a used power pack.)"
"hello
i have a 1981 90 hp j
"hello
i have a 1981 90 hp johnson,and having problem with my power tilt ,have power the pump ,pump runs but the engine will not tilt up or down,what is the procedure to bleed the system if that is the problem"
