I have a 1988 Johnson 20HP (J20ECCA), which has the electric primer. Rebuilt the carb over the winter. This spring it is idling well. However, I noticed that turning the low idle adjust screw has no effect on the idle. I read some threads on models in this year range and realize that I mistakenly put the plastic needle bearing seat in (was included in the rebuild kit. I took the plastic seat out, put the needle screw back in and till find that the screw has no effect ( and engine is idling well!!) I can understand that there could be some type of obstruction of the perfect configuration that is metering the gas when the screw is turned out, but how the heck can the engine remain in perfect idle when the screw is turned ll the way in? Could my primer system be leaking into the cylinders at the perfect rate?
