Martin1988Johnson
I have a Johnson Outboard 140hp that ran great all that season. I've run though a few checks to try to diagnose the problem but my limited outboard knowledge is not helping the situation.
Compression test looked good - All (4) right around 120
Plugs need to be replaced - they look a little oily when I let it idle in the driveway
Ignition coils are new
Fuel pump is new
You'll see in the video, it runs hard while idling and then once I put it in neutral and push it a little the engine sputters/bangs at the higher RPMs
Any help would be more than welcomed!
Fuel pump is new
