toddsilimperi
507X8C
I've read on YouTube that the water pump on this motor doesn't do well with muffs, but it has always worked for me. Cooling system worked last time I had the boat out 2-3 years ago.
I recently tested the motor with muffs in preparation for the upcoming season: No water spitting out as usual.
I replaced the impeller, which was badly worn but still intact. The new impeller arms are bent clockwise when looking from underneath pump housing. Still no water coming out with muffs OR 55 gal drum filled to several inches above water pump. No exhaust coming out "exhaust snout" into water either, if that matters.
I shot compressed air into each water port with my thumb covering the other port. Lots of air bubbles coming out "exhaust snout". That would indicate there's no blockage in water lines, correct?
I've had the lower unit off this motor 3 times now trying to solve this issue. Any suggestions?
