1988 Evinrude 9915 Questions
eman760
"What fuel mix should I be usi
"What fuel mix should I be using for this engine. It says 100:1 on the side? I also saw earlier posts that it should actually be 50:1. Also, any idea where I could find a users manual for it?"
100:1 was a marketing driven b
100:1 was a marketing driven blunder.Use 50:1 to make the motor last.
"Ok, Thanks. Also, the model
"Ok, Thanks. Also, the model number on my engine is E10RLCCD. I have found that I cannot locate the manual for this specific model number on this site. Any suggestions."
This motor was basically the s
This motor was basically the same from say 78 to the mid 90's so any manual will do.
"Why would there be no water c
"Why would there be no water coming from the water pump indicator when I started the motor? I can think of the obvious, the pump isn't working, but I would like to think it is some other reason."
