New water pump, thermostat pumping lots of water. Appears no blockages. Witts end. Could leaky head gasket or too lean gas mix cause overheating? Runs fine until the warning. Owned for 7 years never needed to touch the engine.
Did you actually check temperature with an infrared temp gun.?New water pump, thermostat pumping lots of water. Appears no blockages. Witts end. Could leaky head gasket or too lean gas mix cause overheating? Runs fine until the warning. Owned for 7 years never needed to touch the engine.
