1988 evinrude 25 hp
jredmon
is there suppost to be water coming out of the exhaust port holes on the back of the motor when it is running can anybody answer that for me?
I believe so, but its just a fine mist.Hold your hand 4 inches from the exhaust while its running in the water,You should see the moisture then.That motor has a telltale doesnt it?? some call it a peehole and some other names? is it emitting water?
I have an '88 30hp and it pumps good water using a tank or muffs. If running in a tank, make sure the water level is at least a few inches above the water pump.
