Hey Guys,
Just found this site & joined.
I have a 1988 23 ft. walk-around w/ aphla one v-6 and I'm having overheating problems.
Took it out last month and after about a 1/4 mile down river it started overheating, steam from out of the water, temp gauge was max. out. I shut her down and let it cool. I have a trolling motor on it so I was able to get back to the docks using that. Talked to my marine repair shop & he said that it showed like the inpeller so I had him put a new kit in it and he teast run it. said everything was working fine.
This last weekend take it to the river again & I'll be damned if it did do the same thing again, made about to the same spot as last month. This time no steam, but it was red lined on the gauge & I pulled the engine cover and you could see that the gasket between the manifold & the thermastat housing was sizzling so hot you could have fried bacon on it. So let it set all afternoon to cool down. thought ok I could fire it up and make it back to the docks. Well it made it within about 100 yds of the docks when the radiator cap blow & the motor couched a couple times and died. It blow steam & water all over the place. So, my question is thermastat, water pump or inpeller again or just replace all the three? do you think just off the top of your head that any damage has been done to the motor.. Oh, forgot to tell you this is a closed coolant system.
Thanks guys,,
Thanks guys,,
