Hello Thanks in advance for your help.. 1988 90 Hp Yamaha Motors runs very well Shift shaft is the original Non Stainless Steel metal is getting thin but it still shifts. Over the last year new Tilit trim motor and new water Pump..
Just did a recent compression test number are ALL even at 87 87 87 (Tried a different gauge with same results)
My question is I understand to change the shift shaft the power head needs to be removed.. Do I keep the P/head going or change out. I have seen most 90 HP Yamaha compression number above 120?
Any thoughts here? I know the P/Head bolts are going to be a bear I was going to have someone do the work....I love this motor It is light weight and has plenty of power to move my 17ft Bos Whaler along But those low number have me concerned...Thank you
