Should someone have had the lower unit off and turned the shift rod out of adjustment, have it put back into adjustment as follows.
Lower unit removed, lower unit in neutral, measure from the top surface of the lower unit to the center of the shift rod hole. Measurement is: 88hp thru 110hp = (L) 21-27/32" - - (XL)26-27/32" plus/minus 1/32". Have shift rod in neutral.
However, before going to all that trouble, try centering the shift cable as follows:
(Centering Shift Cable)
(J. Reeves)
When all is as it should be, the proper method to adjust the shift cable is to disconnect the cable from the engine. Move the shift linkage on the engine to find the center of the play in neutral, and when found, leave it centered.
Now, grab the end of the shift cable sleeve, push and pull it to find the center of the play there, and center that play.
Adjust the trunion on the threaded portion of the shift cable so that the centered play of the cable lines up with the centered play of the engine's shift linkage. Install and lock the shift cable with the retaining clamp in that position. That's it.
