Hey guys
I have a 1988 85hp force, My ? is that at idle the motor runs fine when I give it the gas I only enough power to push the 17' bayliner not enough to get on plane.
I then took it home and started to trouble shoot Hears what I did Comp 120 on all 3 cly. new fule pump carbs cleaned. I dont have a spark tester and I did it the old way with the engine runing at idle on muffs I pulled the top plug wire and the motor doged pulled the middle wire and the motor doged pulled the bottom wire and the motor ran the same. Is it the coil or somthing else
