I have twin 1988 5.7 270hp Crusader Engines. Just recently the Starboard engine will lose power and seem to miss,lose power and bogdown after running 30 minutes under load. It runs fine in Neutral or low power to 1500 rpms. When this happens you can push the throttle up and it will start to climb in rpms for 5 seconds then will bog or stutter like losing fuel. Seems to run a tad rich also. Carbs are old and so is fuel pump but all ignition parts including coil are new. If it sits for awhile it will run up to almost 3000 but never where it should and then start to slow down and lose power then bog. 1500 is about all she will turn. No overheating. When this started at 2800 rpms I heard what I thought was spark knock or pre ignition until I throttled back. My thoughts are fuel pump and or Carb issue. What throws me about carb is why would it wait till under load after time? Possible fuel pump issue?
I have a new pump and was going to install. Carb I would say no matter could stand to be replaced/rebuilt
