brian_from_boston
"Still learning here. I tried
"Still learning here. I tried to follow the coolant hoses (both antifreeze and raw water). It appears the antifreeze is plumbed from one side of the HE down to the circulating pump, throught the motor, out the thermostat, and through the manifolds before returning to the HE.
It appears the Raw Water pumps through raw water pump, through ATF Cooler, to the HE, out through exhaust elbows, and exits boat through exhaust.
Do I have this correct? If so elbows should break down faster than the manifolds right?
How often do you guys change the Antifreeze?(I understand that it is a 50/50 mixture)
On the raw water pump, I see the 2 bolts on the bottom of the mounting plate. Is this also the tension adjustment for the belt?"
