Well, I finally found out why the 40 on my 8'-6" Adventurer SE wasn't making any HP/RPM. No timing! Apparently, I fixed the carb and didn't know that the last guy that had it had the timing severely retarded. We couldent load the motor in the tank, as it just moved the water away from the prop and it RPMed fine, until we got to the lake and the engine just bogged. We finally strapped it securely to the trailer at the ramp, and loaded it at the RPM where it bogged and checked everything. I just advanced the timing a little at a time until the bog went away, whenever my manual gets here I will set it correctly. Since last post, I smoothed the reed/manifold area, installed countersunk hardware there, ported the entry to the reeds, installed Boysen reeds, made a cool aluminum inlet radiused venturi, opened up the exhaust exit in the lower at the rear bearing area, opened up the exhaust slots in the props(I have 4), had the two used props (9" and 11") checked/rebuilt and added cup, replaced the fuel/ oil with new, and am ready to take it to the lake(45 miles) Saturday. Can't wait! I have tried 3 tachs that work on other 2 stroke engines, but none function correctly on this one, (it just jumps around) does the Nisssan need a special tach? It seems to me that this engine should pull a much bigger pitch prop too, what is normal? I have a 13 and 15 also, both new. It didn't seem to like the 13", it took forever to get on plane with just me in the boat before the power mods. I would like to get a working tach before I go to the lake this weekend. Any ideas what I should expect? Anybody know what this rig should do? or even what a jon boat runs like with a Nissan 40 on it? No one around here (Phoenix,Az) has any Nissan experiance on anything! I have heard that this combo in stock condition runs 35/40 MPH, but with a 2 to 1 lower gear ratio and an 11" prop, I can't see that. Thanks for any input. TIMINATOR
