Phillips_211
OK so I was on the river the other day going bowfishing riding down the river when the motor just shut off. I figured the motor flooded it self like usual and I needed to just let it sit for a bit. But this time it would never crank back up. Every once and while the motor would act like is was about to crank up then didnt. The motor has had problems with running weird recently. Normally whenever I crank the motor it is at a high idle and when put into gear will run like it should at about 25mph. Then every so often I will crank the motor up and it will be idleing lower than normal and when I try to put it at full throttle it doesnt run wide open like it should it will go about 5mph max. I can sometimes work the throttle back and forth and it will correct itself and run right again. I took carb off and cleaned it and put back together and still no luck. My next thing is getting some new spark plugs. I have checked all the stuff I know to check such as fuel getting to carb and compression and spark, but dont know if spark plugs are at fault or not. If anyone could help me out with this I would greatly appreciate it.
