I was helping a friend who just bought a 1988 cruisersinc with a 260 Mercruiser that has been sitting about 2 years. The previous owner probably didn't do a whole lot to winterize it. We haven't been able to get it started after changing the plugs, new batteries, new primed fuel filter, checked the shift interrupter switch, The distributor cap and rotor look ok. We've tried cranking it over after priming the carb with gas and also with starting fluid. We checked and saw spark on the one wire that we tested. The ground on the ignition module was cleaned. When cranking the engine it sounds like it wants to start, but won't. I suspect it is an intermittent spark. When the dist cap was off, we noticed that there was some rubbery looking sealant? around the pickup coil. Is that normal? What is the pickup coil ohm reading supposed to be? We are running out things to check. Any suggestions
