1988 260 tilt trim pump leaking oil
tuna_man
"Constant run of oil leaking f
"Constant run of oil leaking from res below pump. Its the single screw type, I can see a split in res near screw. having trouble finding merc replacment res. are they available? i found a siera SIE18-667,or maybe SIE18-6769-1, not sure which is the correct one. Is aftermarket OK? Thanks for any help."
"<[img]"http://www.marineengin
This one"
isn't there a new new new
isn't there a new new new design that replaces the single screw with 2 top down screws ?
"Thanks guys, ill order the me
"Thanks guys, ill order the merc883166A2. think its US $65. I read on a website somewhere that it wasnt avail genuine. can find that link now, ne way ill give it a go.
By the way, If I decide to replace the whole pump, do I still get the older slyle single screw unit, or is it superceded by the newer 4 screw unit? Thanks Mark."
