Does this model have an impeller in the out drive as well as a seawater pump on the engine?/QUOTE]
Does anyone know the answer to this ?
or the elbows are due to be changed.....
Donno, you haven't said which drive is on it,.....
Either there's a raw water pump on the motor, or it's in the drive, if it's an Alpha drive,.....
Post a drive number
Which elbows are you referring to?
I haven't seen a forward engine w/ jack shaft for a few years.
Just what are you doing?
Are you putting together a Forward located engine w/ jack shaft arrangement, or are you doing maintenance on a forward engine w/ jack shaft?
And yes..... photos would be helpful!
serial number says its a `83-`90 Alpha
When running at higher RPMs (not idling) temp is fine but at idle or low rpms the temp gets up to 200F Normally runs at 160-180.
Does this model have an impeller in the out drive as well as a seawater pump on the engine? What is the most likely cause of this problem?
Yes it is a 1988 with an Alpha drive
If the A drive pump has been circumvented and an engine mounted seawater pump has been added......... you will still want the upper unit cooling provided by the A drive pump. Pull the lower unit and see if the seawater pump is active!
83- 90 should be the Alpha1 but I think the hose size should be 1 1/4 from the transom to the engine
