Kelly Hannan
Bought it cheap not running. Pulled carb for cleaning and rebuild. The idle tube had rotted off. Tried to use tube in carb kit but it was to big. Found a piece of fuel line for weed eater and cut to length. Put the carb back on and motor would run with choke half on. Pulled carb again and found small tube on plastic idle block was clogged. Motor starts good, idles, and runs great wot. When returning to slower speeds motor dies unless choked, once back at idle speed it's ok, accelerate to wot again ok. I ordered correct idle tube, waiting for shipping. Also new fuel pump, fresh gas, tried two tanks with different hose/bulb. Any suggestions?
