"I have to disagree with you R
"I have to disagree with you Rollie. The VRO is among the best oil injection systems ever made. During it's first two years of use, there were some probemes with ethanol compatibility. A few other minor tweaks, and they had it perfected within a couple years of it's introduction. It was successfully used for more than 20 years!
It's simplicity is what makes it work best. The oil pump and fuel pump are operated by the same air motor. This means most any failure will not starve the engine of oil without also stopping fuel delivery. Contrast this to a gear driven pump that can stop pumping oil while the engine continues to run on straight gas. Instant powerhead failure. The VRO system is the only oil injection system to offer a no oil warning.
I don't know much about the Yamaha system. Mercury's sytem with the pressurized tank in the boat feeding a small tank on the motor, which feeds the gear driven pump, which feeds through multiple fittings, valves, and hoses is certainly not more reliable than a VRO. Read the link JWB posted. Lots of good information."
