Hi All
New to this forum, please bear with me on this request.
I have an outboard that we rescued from drowning last year , it has been in the shed until now and I decided to get some spares and see if I could get it running again, Problems are as follows>>
Model serial no longer on plate only info I have is from the core plug BJ15BALCCS / R7789727, as far as I can make out its a 1988 model this needs to be confirmed so as to get the correct spares, any help appreciated.
We have soaked the block and got the power head to turn over (it actually fired up for a few seconds) so we know it will start.
I now need to get the speed control unfrozen (The plates under the flywheel connecting to the sprocket shaft that would normally be driven by the tiller arm) as this has seized.
The water pump will need replacing, and I'd like to check the lower leg seals etc.
my question is how do I unfreeze the plates and what else should I be concerned about or need to fix to get this back to a good running order.
I need to confirm the year/model so to order the correct spares again any help most welcome
Thanks in advance
George M
Thanks in advance
George M
