Hey all,
(I'm not the owner or user...but am helping the owner)
1988 120 VRO. Has run great for 3 years. About 1 month ago owner launches it, it starts ok, then dies. Can't get it started. On a hunch, I checked for water in fuel...almost a full gallon of water in the tank! Take it out for a test drive and although it now ran good again, every now and then it would slow down on it's own as if it were running out of gas. I would pump the primer bulb when this happened with no change. Assumed water was still floating around in gas, so we then brought the boat home, completely drained the fuel and refilled. (Also added correct mixture of oil as the VRO has been bypassed).
Thinking the problem was fixed, he then took it out for a family day. He said it would run great sometimes, but was still bogging down. He changed the plugs and said that fixed it temporarily (?) but by the end of the day was doing it again...bogging down. He did not try the fuel bulb test while running but he said the bulb is staying inflated, not going flat or anything.
We ordered the VRO FUEL ONLY fuel pump, and installed that along with a new fuel filter and new hoses just to be sure. It started and ran fine in the driveway, so I sent him on his way.
He just returned from a fishing trip and he said the boat would never plane out and he only got up to 18 mph at the most. (Usually this is a 32 mph boat). And said it was running rough during this time, but was intermittent but never did run well.
This has got me stumped. I physically saw more than a full gallon of water come out of the tank that first day. Seems it is a multi-problem now. It has new fuel pump, hoses, fuel+oil, and spark plugs.
I told him we were now going to start with the basics. I plan on doing a compression test and a spark test.
If the compression and spark are ok...would any of you suspect the carbs need to be cleaned or is there anything else obvious to check? he's ready to sell it. I'm getting tired of working on it for free.
Randy
Randy
