alwaywrknonit2
"Help me out here guys. Im rip
"Help me out here guys. Im rippin my hair out. My motor went down on me in Sept. It just shut off. I had a mechanic test it and he said the stator was bad. I put a new stator in it and cleaned up everything. This motor has a new power pack, plugs, wires, coils, rectifier, fuel pump. I got spark and the motor started. It seemed to run fine the other day. I took it out for a test run. It idled fine and went up to 1/4 plane speed. After 10 minutes, it slowed down. I gave it more throttle and it came back up. It then bogged down and shut off. I squeezed the ball and it started right back up. It raced but you could tell it was fightin to run. It then shut off. I drifted into the marsh and began workin on it. Many times, it would start and fight to run but shut off. It never started again. The gas in the tank isnt but 3 months old. Once towed in and back at the house, I checked the spark in all the cylinders and I have spark. But nothing to write home about.Im thinkin the flywheel may be to blame. It shows signs of wear and tear. Could this keep the motor from firing a good hot white spark? The fuel tank was full of fuel. Im thinkin the plugs fouled because of lack of hot spark. I pulled the plugs when I got home and the plug on the top left(standing behind the motor) was dry. The others were wet. Once trying again, they were all wet."
