Hey folks,
Recently picked up this boat second hand and have been running into issues with motor. The motor runs fine and idles great however when I have the boat in the water and apply throttle With engine revving up and beyond 2200RPM (under load) it basically bogs down totally and dies unless I retard the throttle. So far I have checked the fuel system and there are no obstructions and it’s pressure tight. The fuel primer bulb flows correctly etc.
Im a newbie and fiddles with the ignition timing stopper (turned it counter clockwise to loosen it up thinking I controlled the idle speed, realized afterwards where that screw was). So yeah now it bogs down under load. My question is. By setting the ignition timing stopper back to its original position will that allow me to have correct timing advancement and therefore power under load or is it perhaps the doom of clogged carbs starving the motor of fuel?
