" I have a 1987 XP Evinrude 15
" I have a 1987 XP Evinrude 150. The tach registers idle speed of 750 rpm and up to 1,000 r's but when you throttle up the tach drops to zero and stays there. The rect. is putting out approx. 13.6 volts. The stator leads put out zero volts,I read it should be 200 volts or more(yellow and yellow-gray). The motor runs good but is picking up a miss at steady rpm throughout the throttle range. The stator has some discoloration or dark spots on some coils. Stator price is $342. Is this a stator problem?
Thank You
Troy "
Thank You
Troy "
