1987 johnson 70hp
normys
Just bought a 87 70hp triple c
Just bought a 87 70hp triple cyl.Has low center cyl compression 75lbs.has not been run in about a year.Is this a mooring now or could it just need to be run? Possible stuck rings maybe?upper and lower are 110lbs each. any help will be greatly welcomed thanks. Norm
"pull the cyl hd and ck...w/co
"pull the cyl hd and ck...w/comp that diff,somethings going on....hopefully,..bad hd gasket....."
