JohnBerling
Hello, I have a 1987 Johnson 225 VRO that I got back from a local repair shop after they gave up on it. They put 6 new carburetors and coils on it, drained out all the old gas, replaced all the fuel filters, put 6 new Champion QL-77JC4 spark plugs in it, and replaced the battery.
They also tested the fuel pump and the engine compression: 80-85-85-78-81-84
When I picked it up, they said it would start, idle, and idle in gear, but wouldn't throttle up in gear.
Since they were stumped, and the compression was so low, I didn't want them chasing it any further, so I took it out on the water to see if it just needed to RUN (it had been sitting for a few years - don't know how long).
I read (on this forum) about a starting procedure for this engine that has made a big difference in getting the engine started when it's cold, but I still have the following issues:
Engine idles VERY rough in neutral, but idles and revs very well when the throttle is advanced in neutral.
Putting the boat in gear without it stalling takes jerking the throttle from revved in neutral, to neutral, then jamming it into gear before the rpms drop too low (obviously bad for the gears!).
At true idle speed (no wake),the engine will stall within a minute or two, after which it is very difficult to restart.
To get up on plane, I have to hold in the (primer pump) key until I get above about 3000 RPM. Once it's up and running, I can throttle up to 5500 (haven't pushed it to WOT), or back down as low as 3000 without any problems. The engine sounds good in this range.
If I slow back to idle speed, the now warm (not hot - can still touch the head) engine will stall right out, and restarting the engine takes anywhere from 1-2 HOURS of trying.
Other info: The bulb never gets really hard, and the sight glass inline after it does not stay full. Even with fuel showing, the bulb will go soft again within a few seconds. Pushing in the key drains the sight glass. Sometimes the bulb will be firm, but there is no fuel in the sight glass, as if it is full of air under pressure.
The shop I used was not a Johnson service center (we don't have one within a few hundred miles), but they didn't seem like crooks - called before every part and trial, and returned all replaced parts to me.
So, we're both stumped - any suggestions???
Thanks,
John
Thanks,
John
