I have a 1987 Johnson 120 that will run as long as I pump the gas into it. If I take the gas line off of the VRO pump it shoots out a steady stream of gas when I pump the bulb but when I crank the motor and don't pump the bulb the gas barely trickles out. I'm leaning towards needing a new VRO pump, which aren't cheap. What do you think???? If the VRO pump has quit working, is there anyway to repair it or bypass it altogether? Thanks for your help, Jeff
