frank_winns
"Purchased this boat in May of
"Purchased this boat in May of this year. The person before me had the carb rebuilt, tune up, cap rotor, wires, coil. All look to have been replaced. Fuel filter is newer. Drove boat all summer. Last week a buddy and I went out and the boat was running great. About 45mph, when suddenly the motor bogged out and stalled. The tach has been inop since boat was purchased. We started the boat up and was fine on take off but if opened all the way up the boaT would fall on its face like there was no gas. Limped it back to dock. Thought we found a faulty supply hose. We fixed that and went back out. 20 minutes later it started doing it again. Mind you this boat has only missed 3 weekends of not going out. GPS I have driven 500 miles. So saturday I remove tank cover, check vent for tank. No unstructions, remove pickup, nothing on screen, remove antisiphon valve and just put straight tee for testing purposes. Replace fuel filter/seperator. Drain old fluid into glass container. No contminets or water. Take boat out for over a hour. Boats running 48 mph running great planning great. All of sudden boat starts to gradually slow down. Temp outside is under 70 this day. Was cooler other day also. Go to plain, boat can barrely get out of own way. Has no backfiring, or running out of fuel like the ohter day. Boat would barel hit 35mph. Did notice that if I went from full throttle to neutral motor would die. Gas gauge would go to e and boat would stahl. I beleive the tank to have enough gas. Do not want to fill it all the way up incase I need to remove the tank. Plus Oct 15 rack and launch closes. I am a auto mechanic so working on things is not a problem. Just puzzled that all summer no problem. I didn't pull plugs, or take a compression reading. It does have a mechanical fuel pump. I figured if it was the pump it would run like crap all the time. Just need some guidance."
