truck300lb
"I got a 87' 50 force mod.
"I got a 87' 50 force mod.# 507X8D on A 14' bay liner and it wont idle once it starts it will stay running but only if you flutter the throtle if I give it full gas it winds out good but if I let off a little it will die .in the diagram for the carb. says there is a spring(nozzle spring)#26 part # 24-f10204 and this carb has no spring there and was woundering if that could be the problem.... I have new fuletank
fule line
primer bulb
fule
and I screwed the adjustment all the way in then out 1-1/2 turns on the back of the carb. any answers???????????????????? THANKS, Jeff"
fule line
primer bulb
fule
