Now that I've removed my VRO pump and have my new OMC fuel pump, it looks like one OUT hose from the new fuel pump will go to the crank case. My question here is, does the other OUT hose from the new fuel pump go to a NEW OMC fuel manifold (PART#394385)? The way I have set up now, is the primer is connected to a long thin manifold with three very thin fuel lines connected to the three carbs individually. From what I can see, I think the second out hose from the fuel pump would go to the OMC fuel manifold/splitter with the three hoses going then to the carbs. This is what I think, I don't know. Should the three carbs have separate fuel lines coming from the primer AND the new pump?
Thanks,
- Tim
Thanks,
- Tim
