Hello all,
as the title states I’m having an issue with my 1987 evinrude 60 hp. Or several. So to start I’ll list what has been done currently. New parts include starter, fuel pump, spark plugs, carbs rebuilt, power pack, rectifier, fuel tank, fuel hose with new primer bulb, all new fuel lines on the engine and I believe that’s it. So when I fire the engine up it will not idle. If I give it some throttle and up the rpms to about 1200 or better then I can get it to idle but it has a nasty backfire through the exhaust. The #1 cylinder spark plug once pulled looks perfect nice and tan. The #2 and#3 cylinder spark plugs once pulled are not good. The #2 spark plug comes out black and wet and the #3 plug comes out black and dry. There is no air fuel mixture that I know of on the individual carbs. Can someone please help me out. I believe it may be timing related but I can’t set the timing without it being able to idle at the proper rpm. If someone can shoot me in the right direction that would be great.
thank you.
thank you.
