guido2
"This was a pristine well serv
"This was a pristine well serviced motor, had recent upgrades to VRO before signs of trouble. Customer hit underwater object at full speed end of last season with enough force to moderately damage prop, missing the skeg. Tilt/trim began leaking down from that point on. Customer brought me boat (primarily used for fishing small inland lakes here in MN). I repaired trim/tilt with used parts and rebuilt both cylinders with marginal improvement. Checked prop shaft and about .005 runout about halfway point. Replaced prop and checked torque on flywheel. Customer took out and on about 3rd tank of fuel, burned up #1 rod bearing. Bad knock the result. He wants insurance to cover the rebuild or replacement so I was instructed to partially tear down motor. Compression test #1 45psi #2 90 (my gauge runs little low). Pulled head, no wear or scoring or lack of oil. Lower rod beatiful. Without removing #2 piston I degreed crankshaft and found 2 to 3 degree off from TDC #2 to TDC mark on flywheel. After removing flywheel to check keyway for damage (all ok), then replaced flywheel, found still 2 to 3 degrees off. Showed all this in front of insurance adjuster and he won't buy that the crankshaft is twisted or bent. Does anyone think we have a case here? Motor is not covered but he will repair prop and trim/tilt unit. Would 2 or 3 degrees indicate enough trama to crank/rods to cause this failure? Rod bolts on #1 were finger tight. Thanx.....we need a real pro on this one. Tim"
