Hi Everyone,
This my first post on this forum. I have frequented this forum quite a bit and it has saved me thousands, thanks a lot for the helpful advice. The backstory on the boat, it is a 1987 Bumble Bee 178DF. It is an ok boat but I very uncharacteristically bought the boat with very little knowledge in the area and as a result, it has been a nightmare. It had a number of issues that manifested themselves, the first time I took it out my steering wheel popped off! It had been tack welded on. I have hammered down most of the issues and the after replacing lots of parts it runs great, starts right up even in cold weather and will run about 45-50 with a 17' 8" boat. One issue that I have not been able to overcome is the shifting. When I first got the boat it would intermittently go into reverse and then eventually wouldnt go into reverse at all. I have replaced the shift cable and adjusted the shift rod to the 22.06" off of the lower unit housing based on the seloc manual (Huge waste of money). I can get both forward and reverse to engage by hand, but when the shift cable is on it doesnt seem to have the range needed to engage both gears. I have adjusted the shift rod one turn at a time up and down and reinstalled the lower unit several times but I cannot get it right. I can get one gear to engage but cant get the other one to work as well. There isnt a lot of play in the shift rod when the lower is removed and it shifts into forward, neutral, and reverse cleanly with no grinding or obvious issues so I dont think the issue is in the lower unit. Ive looked at the exploded diagrams and it doesnt seem like anything could get bent inside of the lower that would affect the range of throw for the shift rod either. I did read on one of yalls forums that the shift lever could be adjusted but I couldnt find anything else on this. Perhaps this is the issue? I was about to sell the boat to get rid of it out of frustration but I have decided to defer to you all instead.
As far as bringing it to a mechanic locally the one closest to me wont work on anything older than 1991 and the next closest worked me over pretty good and didnt do anything to my boat. The repair bill started at around 1800 then ballooned to almost 4k over a three week period so I picked it up and did the work myself squeaking out of their out only 1700 with a box full of overpriced parts and almost no work done
. The mechanic at this shop did say he pulled the lower unit and said the gears and clutch dog looked good so take that for what it is worth. Thanks for the help in advance.
