1987 evinrude 140 E140tlcua
Update I replaced the reeds with Chris Carson sport reads and all new gaskets , used a bore scope down cylinders and pistons and walls look good , plugs are all black and wet , took boat out today and no change , disconnected voltage regulator and no change , I feel like spark is not advancing I may have gotten bad timer base .
Plugs
The spark advance is by the timer base rotating as the throttle is advanced.
Either it works or it doesn't as far as producing spark. When it sparks (as in timing) is mechanical linkage.
I’ve already replaced timer base and set high speed timing , but I’m at a loss here as to what’s the issue , bad cdi parts out of the box is not uncommon depending which plant they came from , I got the motor set at 3” below prop to pad I’m gonna drop it down couple inches in the water and see how it reacts
Update , tested the new cdi timer base and im only getting .2-.4 volts from white to other wires , minimum is .6 volts , going to warranty it and go from there
Update , determined timer base fine , bought oem coils and wires , checked float levels , lowered jack plate , will get on plane but reely needs weight up front cause once I leaned forward for a minute I can hear the tone of motor change and 30 seconds later the bow will come down and jump on plane and take off hard and run great at top speed it gets 51.5 mph , has anyone had a negative effect of adding a jackplate ?
This is a long shot, but it's possible the foam in the hull is waterlogged and you're running much heavier than designed. JD Power specs on your boat says the hull minus engine, fuel, and gear is supposed to weigh 1,120lbs. The specs on your outboard is 365lbs.
If you have a scale locally (gravel yard, truck stop, grain elevator, etc.) you might take the boat there and get a weight of just the boat and trailer. I don't know if you can find the weight specs on the trailer, but maybe assume about 750lbs for the trailer itself. Also, estimate the gallons of fuel in your tank and multiply by 6 to get the lbs. Roughly, the boat + outboard + trailer should be about 2,235lbs. If your scale weight is drastically higher than that amount, then you likely have a waterlogged hull. Depending on how much water is in there (8.3 lbs/gallon) it can make the boat plow the water and take longer to get on plane.
From what I can find in the service manual it DOES NOT but if there were any supersessions in the power packs maybe one it does now?
If it had S.L.O.W. it would have had to have the complete ignition from a newer engine. A SLOW powrpak may have been put on that that but it wont have the SLOW feature.
This is a very good response thank you for your input however my previous 1982 90hp on it jumped on plane quick , no jackplate unknown prop it ran 5500 rpm about 36mph , I wanted more speed so I go the 140hp , might put my trolling motor batteries up front and fill front live well I’m sure it’ll be after that lol , it’s odd though takes forever to get on plane but once it does it pulls hard
I'm not going all the way back to the beginning to review.... I'll just ask....
Did you do a link & sync? If it's wrong, the timing can lag & cause poor acceleration (actually low & mid range performance) but eventually the trigger will rotate to full max timing. From that point to full throttle it should run properly.
That would explain sluggish acceleration but good full throttle speed.
Yes linc and sinc has been done using the manual
