1987 dt115
the7carrolls
Havechecked compression and re
Havechecked compression and readings are 120 on all 4 cylinders. My motor smokes alot and back fire constanly. Have rebuilt the fuel pump and clean the carbs. What could be causing my engine to backfire. Can you cahge plug wires or do you have to purchase new coils? seems like the wires are built in to the coil.
change the check valves on the
change the check valves on the oil pump lines for the smoking if a motor sets awhile they stick open
