90hpwhaler
"Overheat buzzer going after r
"Overheat buzzer going after running below 900rpm for a minute or so. Water is coming out. Problem does not exist above 900rpm.. I'm assuming because water is forcing its way through the system. Local shop thinks it may be thermostat problem; I was thinking pump. What do you all think? Also, I notice there is a pressure control valve around the thermostat... could that be the culprit??
PS, this boat has been run in the upper Potomac it's whole life, very low salt content."
