Here is a quick cliff notes of my problem I just can't solve. I have a 87 Mariner 9.9hp.
BEgan starting hard & leaking fuel. The enricher gasket went. Replaced enricher & motor was still hard to start and didn't seem to run up to speed anymore, but still was reliable.
Began taking 30 pulls and a spray of fuel to start. Was down on power but still ran.
Kept taking 30 pulls and a blast of fuel to start and was considerably down on power and would bog heavily at half or 3/4 throttle or more.
Completely took carb apart and cleaned. Needle was spotless, rest of carb was soaked, blown out, etc. Replaced fuel lines, replaced all vacuum lines, new plugs.
Problem didn't go away but engine starts first pull EVERY time now. Idles nice and smooth.
Ordered new gasket & diaphragm kit. Also ordered carb rebuild kit. The motor now runs a little better, but runs like a CHAMP on FULL choke. Unless it's on full choke, it will bog out.
I'm completely lost. I feel like something is out of sync with the butterfly arm and the throttle cable & arm? I noticed on the butterfly arm, the white piece that is on the throttle arm & slides when the throttle is opened, has a small adjustment in it and it looks like over time the screw & nut didn't hold tight and it has moved. So I went to play with it and voila, the nut fell off and into the lake it went.
My only concern from the carb rebuild was the float. It has a lip on one end & I didn't notice how my old one came out of the carb. Right now I have the lip end upright.
