I have this 87 70 hp evinrude it has good spark good compression 120 on all cylinders it sit up for a while couple years.I took carbs off and cleaned them twice. because it would run good but when you put it in the water it would just die as soon as you put it in gear. but on land it would run fine. the second time I took it off and cleaned it I soaked it in carb cleaner for 4 hours, i ran a small wire thru the tube that goes up int top of carb it seemed like it was clean. I noticed when I waas in the water with front off car that it was spitting some gas from top carb an bottom one. also you have to choke it everytime you start it in the watewr even though its warmed up. can someone tell me what to do. i also put new needle and seat in it.
