I have a 1987 2 stroke 70 hp Yamaha outboard that sat several years before I got it. Compression 130,130, 125. I cleaned carbs well getting all jets open. Put new fuel pump and fuel lines on. Replaced water pump. It cranks and idles great. It runs very smooth from 2/3 idle up, and if backed down once it accelerates it runs smooth at about half throttle up. I set the carbs according to manual (I think 1 5/8–but don’t have book in front of me now) and have tried tuning carbs about 1/2 round in each direction with no change in idle or performance noted. Have tried 2 new sets of plugs gapped to proper specs with no difference. My problem is a rough acceleration up to point pontoon planes—-or as much as a pontoon planes. Engine almost sounds like it is skipping. I have a very flat pitch prop (11) so even thou it is a big pontoon should push it ok. If I gun the engine to 2/3 on takeoff it does fine, but I am hoping someone can clue me in on what I have missed. I did not buy carb kits—-as they are pretty pricy and my gaskets all appeared fine—so I realize that may be an issue. Appreciate the Yamaha outboard gurus pointing me in right direction!
