Highland Bob
I recently bought a jon boat that came with this motor (507F7C). I will be selling the motor, as it is too large for the 14 ft boat. It runs very well and has compression of 132 on the top and 126 on the bottom. I changed the foot grease, installed a new impeller, and added a tell tale. I ran it in my barrel for 10 minutes or so before taking the boat to the lake for its maiden voyage. When I got to the ramp and was preparing the boat for launch, I noticed gear oil seeping out of the hole in the pictures below. There are 3 pictures which get progressively closer to the hole. It is located about 2 or 3 inches above the pointy part of the gearcase, then to the left an inch or two. I had bought the Clymer manual, but the lower unit in the manual is not exactly like my lower unit. Either the manual is wrong or a different lower has been put on this motor. The hole was machined, but I can't tell if it's threaded. So, my questions are:
1. Is there supposed to be something threaded into this hole, and if so, why is it here?
2. If there is no factory plug for it, could I fill it with JB Weld?
When I changed the gear oil, there was some water in there unfortunately. I know this hole will let water in if it's letting gear oil out, so I need suggestions on how to handle this. I can't, in good conscience, sell this motor to someone knowing that the lower unit has an issue that will lead to a catastrophic failure.
Thanks,
Bob B.
Thanks,
Bob B.
