Have twin 1997 Crusader 5.7L 350XL fuel injected engines with 708 hours on them, port engine runs fine with no issues but the starboard engine will not run as it has bad compression on cylinders 3 and 5 nor will these two cylinders hold compression. Both engines power twin V-drives, engines are set in boat with flywheel/output facing forward to the bow. The boat is a 1997 Cruisers 3075 Rogue Yacht, looking for advice as to what I should do with the starboard engine, what rotation would it be and if 708 hours is excessive enough to go ahead and pull both engines for rebuild before this years boating season starts.
